FMM130 missing parameters
I have been attempting to configure a FMM130 so that it will send a SMS notification when an input changes (such as ignition is on). However the Rev 18 firmware seems to be missing the required parameters.
The configurator doesn’t have the relevant SMS fields in the ‘I/O’ settings page. I have also tried using sms messages to do the configuration (just in case it was an issue with the configurator). The responses from the sms messages are that the relevant parameters are invalid. (e.g. sending ‘ getparam 7000’ results in ‘Param ID:7000 doesn’t exist).
I did update the firmware to the latest version (03.29.00.Rev.18) before attempting to configure this module, so I’m not sure if it was also an issue with the earlier firmware (0.3.29.00.Rev.14).
Am I missing something in the configuration, or is there an issue with the firmware? Any help or assistance would be appreciated.
The sms field for I/O were removed from configurator.
You can configure event notifications for I/O directly through your software portal.
Regards
Maryam
Hello Maryam,
Could you clarify further? Is it possible to configure the FMM130 to directly send a SMS? Or does the SMS have to come from a portal instead?
And which ‘software portal’ is used to configure the SMS capability?
Alternatively, is it possible to use an earlier version of the firmware and configurator that has the sms fields for the i/o? I’m keen to have the FMM130 issue notifications directly via sms rather than rely on a portal, if that’s possible?
Hello @chrisp
The I/O event configuration has removed from the I/O tab of configurator, However, you can still configure the sms event based on the AVL ID (Data Sending Parameters).
Please check the list of AVL ID from link https://wiki.teltonika-gps.com/view/FMM130_Teltonika_Data_Sending_Parameters_ID
To configure the SMS event for Ignition, follow these steps
  • Identify the AVL ID: For Ignition, the AVL ID is 239.
  • Enter the AVL ID in configurator under sms event > sms event AVL ID
Please see the below screenshot
Regards
Maryam
Hello Maryam,
Thank you very much, that is very clear. I have tested it and it works - sms comes through as expected.
Thank you for your help and assistance - it is very much appreciated.
