FMC920, FW: 04.00.00 Rev:14, Configurator: 1.8.10_B.4.00_R.7. New 170 mAh, standard internal battery.
Trying to address situation when device is cut from 12V power source and operates from battery.
Sleep settings: Online Deep Sleep. (most of other settings Default, can clarify specific if needed)
When disconnecting device from 12V power device dies in around four hours. Based on power specification for FMC920 (< 8mA for Online Deep Sleep) - It should work from 170 mAh battery for around 20 hours (if my math is correct).
Trying to find the cause for this and see some issues and maybe bugs in firmware.
- Battery level percentage seems inconsistent with battery voltage. E.g. when charging it shows 74% at 3.878V and when 12V power disconnected after some time it shows even more percentage at lower voltage e.g. 83% at 3.808V. Is this expected behavior or some issue with device or battery?
- Battery current (AVL ID 68) shows values only when charging battery. It always shows 0, when not charging - either operating from internal battery or from 12V power. Is this expected behavior or some issue with device or battery?
- When sending ‘battery’ command (by sms or by tcp server) it reports Battery current instead of Level. E.g. for fully charged internal battery response shows “BatV: 4028 Batl: 0”. Batl always is zero unless it is charging. In this case it reports charging current instead of level. Maybe firmware bug? (battery level enabled in I/O options with priority Low)
- Cannot put device into Low Power mode. When Low Power enabled (with default settings) and disconnecting 12V power the GSM modem stays on with GPRS activated. Maybe “Unplug Detection” in Accelerometer features prevents device getting into Low Power mode? (Record settings Open Link time out is set to default 300s.)
Would appreciate any help or hints where to look. Thanks!
