Hello!
I am using a Teltonika FMC920 GPS tracker with an EYE Beacon BTSID1 to protect my electric bicycle against theft.
Firmware version: 04.02.05 Rev:03.
The tracker already detects the beacon correctly and generates Lost (10831) and Found (10829) events.
I would like to implement the following anti-theft logic directly in the FMC920:
- Authorized EYE Beacon present + movement detected — no alarm.
- Authorized EYE Beacon absent + no movement — no alarm.
- Authorized EYE Beacon absent + accelerometer detects movement — generate an immediate alarm event.
I found that FMC920 supports Accelerometer as an Ignition Source and Immobilizer authorization using Bluetooth beacons.
My questions are:
- Can these two features work together to implement the described logic?
- Can the Immobilizer generate an unauthorized movement event without activating DOUT or connecting an external relay?
- Which AVL event or parameter would be sent to the monitoring server when movement is detected without the authorized beacon?
- Is this functionality supported by firmware 04.02.05 Rev:03?
- Can it operate simultaneously with the existing EYE Beacon Lost & Found events without interfering with their configuration?
- How quickly can an unauthorized event be generated after the accelerometer detects movement?
My goal is to receive an alarm notification, not to physically disable the bicycle motor.
The FMC920 is currently working correctly with the M2M monitoring platform, so I would prefer not to change its configuration until compatibility is confirmed.
Thank you for your assistance!
Good day,
Yes, your proposed anti-theft logic can be fully implemented directly on the Teltonika FMC920 using the EYE Beacon BTSID1 and accelerometer, without requiring any physical relay or motor cut-off wiring.
1. Can these two features work together to implement the described logic?
Yes.
Accelerometer as Ignition Source: Under System → Movement Detection, you can configure the Accelerometer as an Ignition source. When the bicycle moves, the tracker transitions from Sleep/Standby to virtual Ignition ON.
Immobilizer / Authorized Driving: The Immobilizer scenario is triggered by the Ignition state:
Beacon Present + Movement: Accelerometer triggers Ignition ON → tracker scans and immediately detects the authorized EYE Beacon → authorization succeeds; no alarm is triggered.
Beacon Absent + No Movement: Ignition remains OFF → Immobilizer scenario is dormant; no alarm.
Beacon Absent + Movement: Accelerometer triggers Ignition ON → tracker fails to detect the authorized beacon within the configured timeout → an unauthorized event/alarm is generated immediately.
2. Can the Immobilizer generate an unauthorized movement event without activating DOUT or connecting an external relay?
Yes.
You do not need to connect the DOUT wire or attach a relay.
In the Teltonika Configurator under Features → Immobilizer / Authorized Driving, you can select None (or leave DOUT unassigned).
The scenario logic is evaluated internally, and the alert packet is dispatched directly over GPRS/LTE to your M2M monitoring server regardless of physical output state.
3. Which AVL event or parameter is sent to the monitoring server?
4. Is this functionality supported by firmware 04.02.05 Rev:03?
Yes.
- Accelerometer-based movement/ignition detection, Bluetooth EYE Beacon whitelist authorization, and Immobilizer scenarios are core features fully supported in the
04.02.xx firmware series for FMC920
5. Can it operate simultaneously with existing EYE Beacon Lost & Found events?
Yes.
The BLE scanning engine operates continuously in the background.
Proximity-based Lost (10831) and Found (10829) events will continue to trigger according to their configured RSSI and time limits without conflicting with the Immobilizer scenario logic.
6. How quickly can an unauthorized event be generated after movement begins?
Accelerometer Response: Motion detection triggers within ~1 to 2 seconds of physical movement.
Beacon Search Timeout: Configurable in the Immobilizer settings (Wait for Beacon / Authorization Timeout). For quick alerts, you can set this as low as 5 to 10 seconds (giving the tracker enough time to capture the beacon’s advertising interval).
Total Latency: An alarm packet is generated and sent to the server within approximately 6 to 12 seconds from the start of movement.
Muhammad A
Hello Muhammad,
Thank you very much for your detailed reply!
This is exactly the functionality I am looking for.
Before changing my existing configuration, could you please clarify a few technical details specifically for the FMC920 with firmware 04.02.05 Rev.03?
Can you confirm that the Immobilizer scenario generates an unauthorized event when Output Control is set to None, without any DOUT connection?
Is AVL ID 248 supported by the FMC920? What exact value indicates unauthorized movement? The Teltonika AVL documentation appears to describe different meanings for values 0, 1 and 2.
My EYE Beacon BTSID1 is currently configured using the EYE Beacon Name List with Lost (10831) and Found (10829) enabled. Do I also need to configure the separate Beacon List for Immobilizer authorization?
Could you provide the exact Immobilizer settings, including authorization timeout and event priority, for detecting movement using the accelerometer?
Will these changes preserve my existing EYE Beacon Lost & Found events?
My DOUT is not connected, and I only need an alarm event sent to my M2M monitoring platform.
I would appreciate a configuration example for this specific firmware version.
