FMC920 - Custom Scenario
Hello, I am trying to determine the capabilities of the FMC920 in regards to the custom scenarios function.
I understand that I can set a custom scenario so that when an input condition is present from a BLE sensor, Dout is energised.
I would then like to find a way to ‘disable’ and ‘enable’ this through GPRS/SMS commands. E.g if disabled, even if the inputs conditions are present, then Dout does not energise. If enabled, customer scenario works as normal and Dout is energised upon set input conditions. Is this possible?
Is it possible to enable/disable inputs (BLE sensor) using GPRS/SMS commands?
Many Thanks
Hello @LewisF
Good day!
You understand the costume scenario correctly, the input that we are using in the custom scenario can only be disabled by changing the MAC address of the BLE sensor (the device will not receive new values from the sensor)
this could be possible by using the FMC130 (which has 2 Dout)
BR
LAITH
This topic was automatically closed after 17 days. New replies are no longer allowed.
