I am using FMC640 with the SAE J1939 interface. I configured some CAN ID parameters on the device. How can I see the data on the platform? I am using the Navixy platform and Manual CAN parameters are not listed in the sensor list.
For manual CAN data, we have AVL ids from 145.
In this AVL id you will get hex bytes values.
You need to decode these hex bytes according to the PGN and SPN conversion.
So in your server, you may need to add additional script for this decoding.
You can contact Navixy support for that.
Naveen
