FMC150 SMS commands question
How I could get Fuel Level from CAN readout through SMS message? 45150 and 45160 ids I believe are current values?
Dear @user20,
Welcome to Teltonika Community Forum! :slight_smile:
You may read the Fuel Level values through SMS commands by following the command structure below.
If Authentication is set: SMS login(space)SMS password(space)command
If no Authentication is set: (space)(space)command
Fuel Level in Liters command:
readio 84
Fuel Level in Percentage command:
readio 89
I hope this helps.
Patrick S.
Where I could find the additional IDs which were read by CAN? I cannot find 84 in any other wiki:
https://wiki.teltonika-gps.com/view/Template:FMB_Device_Family_Parameter_list
Why I’m getting readio 84 command response N/A? In Configurator I can see the communication and liters in tank etc.
Hi @user20,
Good day! Complete AVL IDs of the device can be seen from this link: FMC150 Teltonika Data Sending Parameters ID - Wiki Knowledge Base | Teltonika GPS
On the other hand, readio SMS description can be found on this link: FMB readio - Wiki Knowledge Base | Teltonika GPS
You may try other AVL IDs to confirm that you were sending the command correctly on the device.
Patrick S.
