FMC150 CAN data - four wheel drive aka fwd, 4x4
Is there a way to see if four wheel drive is engaged via CAN data?
Good Day,
Yes, it is possible to retrieve information on whether four-wheel drive is engaged. However, this is entirely dependent on the specific vehicle.
If the vehicle transmits this data over the CAN bus and the Teltonika FMC150 is connected to the correct CAN lines, then the device will be able to read and display this information.
Thanks, and best regards,
Imran S.
