FMC130 LV-CAN 2000 fuel parameters
Hi team,
I have installed FMC130 connected to LV-CAN 200 adapter which is connected to ECAN. my interest was to be able to read fuel data via the CAN Bus. But from the configurator it’s not showing some parameters like engine RPM, fuel level. The vehicle model that i i have installed on is a Totyota corolla Axio 2013 model. What could be the cause not being able to read some CAN parameters?
Hello @alexmadalo,
I hope you are doing well. When you are connecting FMC130 + LVCAN200, you need to set the correct program number and installation on the device so that you may retrieve the parameters required. Program numbers suitable for each vehicle can be found on the supported vehicle list.
For more information about the LVCAN200 vehicle supported list, you may refer to this link: https://wiki.teltonika-gps.com/images/e/e9/LV-CAN200_list_2025_03_26_en.xlsx
Also, you may refer to this link for setting up the FMC130 with LVCAN200: FMC130 CAN adapters - Teltonika Telematics Wiki
I hope this helps.
Patrick S.
