We are using FNMC130 in order to identify the driver using a 1-wire reader. Using the configurator wew can confirm that the reader and ibutton is working fine, the FMC130 identify the ibutton tag. We change I/O parameters to send a record at the moment the ibutton is readed and works but in the AVL data does not appears the ibutton hex id. With FMB120 works fine.
Any change in te configuration must be applied or can be the gps platform (gpsgate).
Any clue?
Thanks fot the help!!
