Hello Teltonika Support Team,
I am having trouble getting my FMC130 device to connect to the internet. The GPRS Status in the configurator remains “Deactivated” even after setting what I believe are the correct APN parameters.
Device Details:
- Model: FMC130
SIM Card & Network Details:
Provider: UMobile (Malaysia)
SIM Status: The SIM card is active and has a working data plan. I have personally tested it in a mobile phone, and it connects to the internet successfully.
Device Status (from Configurator):
Modem Status: Modern On
SIM State: Ready
Actual Operator Code: 50218 (Correctly identifies UMobile)
Signal Level: Excellent Signal
GPRS Status: Deactivated
Configuration I Have Tried: I have configured the GPRS tab based on the UMobile (Operator 50218) requirements:
GPRS Context: Enable
APN: my3g
APN Username: (blank)
APN Password: (blank)
GPRS Authentication: None
Troubleshooting Steps Taken:
Saved the correct UMobile configuration (APN: my3g, no user/pass, auth: None) to the device.
Rebooted the device multiple times.
Tested the SIM in a phone (it works).
Tried different GPRS Authentication (None, PAP) but none work.
Despite the device correctly identifying the SIM and having an excellent signal, the GPRS Status will not change to “Activated”.
Could this be an issue with the device, the firmware, or is there a specific carrier setting for UMobile that I am missing?
Please advise on the next steps. I am attaching screenshots of my “Status → GSM Info” and “GPRS” tabs for your review.
