FMC130 + CAN-CONTROL no VIN
I have an FMC130 along with a CAN-CONTROL module. In the Excel file, my car is supported by CAN-CONTROL, but I can’t get the VIN number in any way.
In the configurator, I set the OBD parameters to Low, entered the correct configuration code. The CAN-CONTROL module seems to work fine, I can, for example, close or open the doors, or blink the turn signals. Any help appreciated :slight_smile:
Hello
The OBDII section refers to devices connected to the vehicle’s OBDII connector, e.g. FMX003
Therefore, the VIN parameter (AVLID 256) is not available for CAN CONTROL
Parameters for CAN CONTROL should be configured in the CAN Adapter section, provided they are available for your vehicle
https://wiki.teltonika-gps.com/images/8/88/CANCONTROL_list_2023_08_29_en.xlsx
and are available in the AVLID list
https://wiki.teltonika-gps.com/view/FMC130_Teltonika_Data_Sending_Parameters_ID#CAN_adapters_elements
Best regards
