FMC125 with Zebra FX9600 integration
I use the FMC125 connected to the Zebra FX9600 through RS232 TcpAscii mode. What IO number would be sent by the FMC125 to Wialon?
Good day, if you want to received it with AVL ID try to use the Demiter mode.
You will received it in io_109 from Wialon, make sure that the codec 8 extended is activated.
Wiki page link: FMB125 RS-232 and RS-485 - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
is it the same way if I use FMB125?
Hi
Yes Delimeter mode is available from the latest firmware of FMX125 : Firmware versions - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
thank you, do you have wiring diagram for both FMB/FMC125 to RS232?
Hi
FMB125: https://wiki.teltonika-gps.com/images/4/4c/Wiring-scheme-FMB125.jpg
FMC125: https://wiki.teltonika-gps.com/images/3/38/Wiring-scheme-FMC125.jpg
my FMB125 still unable to send RS232 data (Zebra FX9600 integration)
what should I check?
Baud rate 9600 and any other parameters are exactly the same between Teltonika FMB125 and Zebra FX9600
need help
thanks
io_109 not arrive in Wialon
Please create a helpdesk ticket or contact your sales manager to assist with your POC. If you don’t have any contacts with our Sale managers, please contact them on our official website https://teltonika-iot-group.com/ and click on “Contact Us” button. When you click, please fill the form and submit it.
Best Regards
Maynard C
