Just a quick one, I assume on internal battery the FMC125 or FMC225 unit should still read RS232 and send message?
If so, I guess it’ll be the sleep mode behaviours & polling that I’ll need to configure.
Hello and good day,
Power to the RS232 device: The tracker’s RS232 port doesn’t power whatever is connected to it. If that device runs off vehicle power, it goes dead when external power is cut, so there’s nothing to read even though the tracker is still running.
Sleep mode: If you need data while parked, use Online Deep Sleep or GPS Sleep, or turn sleep off. In Deep Sleep or Ultra Deep Sleep, assume nothing gets read or sent until the unit wakes up.
Polling and sending while parked: Set the RS232 mode and its polling period, then the record period and sending period for when the vehicle is stopped. Sending is what drains the battery fastest.
Battery runtime: The internal battery is only meant as a backup. With polling running and the modem on, it won’t last long, so time how long it lasts on the bench with your actual settings.
If you need further detailed technical assistance, feel free to reach out to one of our engineers via Helpdesk in Partner Portal.
Muaz Z.
