Fmc003 send period not working properly
I already posted a question but i didn’t recieve any input. I kept trying myself and came to the following conclusion. Even if a set send period to 5000 (random high number) and i set min send period to 10. The device is sending the data to the server every 10 seconds. How is this possible. Aren’t the “min parameters” supposed to just acquire the records and the send period to actually send the data to the server? And if this is not the case what is the real purpose of send period? This part of the documentation is really not saying what actually happens
Kr
Imad
Hello @imad,
Good day! If the Send Period is set to 5000 seconds and the Min Period is set to 10 seconds, the device will generate records every 10 seconds but will only send them to the server once the 5000-second Send Period has elapsed.
The records will be sent in bulk to your server, as the device needs to transmit all the records generated during that period. This may result in timestamps appearing every 2-3 seconds on your platform timestamp, as mentioned in your initial query.
I hope this helps.
Patrick
I also thought about this scenario. But the thing I’m noticing is as soon as i changed send period to 5000 and min send period to 10. I clicked on save. I started receiving updates every 10 seconds. That’s why i find it very confusing. I also verrified the records, they are not triggered by any event. And the timestamp is from the device, also i verified with the timestamp of the server when it receives a new record. This is also showing that it receives a record every 10 seconds. So the device is actually sending records every 10 seconds. So, the only conclusion i can take is that the min period generates records and send them. Which is not what is mentioned in the documentation
Hello Imad,
Good day! Min Period is only for generating the records and not sending it.
I recommend you to contact with your Sales Manager so we can arrange a session or assist you on troubleshooting your device. If you don’t have any contacts with our Sale managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you will click, please fill the form and submit it.
Patrick S.
This topic was automatically closed after 8 days. New replies are no longer allowed.
