Hi all,
I have a new FMC003 that registers on LTE but never gets a data session.
Setup
- FMC003, latest firmware (04.02.00 Rev 602 at the time of testing), Configurator 1.8.25
- 1NCE SIM (Platform 2.0), APN sensor.net, PAP, empty user/password,
Auto APN disabled - Australia: roams on Telstra (505-01) and Optus (505-02), LTE B3/B8/B28
- 1NCE confirms the SIM is active, quota available, APN correct, no blocks
Symptoms
- GSM Info: SIM Ready, good signal, operator registered, GPRS Status “Deactivated”
- Device log repeats every few seconds:
+ESMCAUSE:33
+CREG: 2,3,…,7 (registration denied)
[GPRS.OPEN.0601] Error: 17 - 1NCE portal shows “Update GPRS location” (success) followed by
“Purge GPRS location” within a second, repeating. No session is ever created. - Same result with APN iot.1nce.net, and with authentication None or PAP.
Questions
- Is there a way to send AT commands to the modem (e.g. AT+CGDCONT?,
AT+CGACT?, AT+CEREG?) to see what APN and PDP type it actually requests
at LTE attach? - Does the FMC003 use the configured GPRS APN for the LTE initial attach /
default bearer, or could the modem be using a different stored context? - Is the PDP type IPv4 only, or IPv4v6? 1NCE only supports IPv4.
- Has anyone got an FMC003 working on 1NCE in Australia?
Thanks!
