Please explain more about GND and where this has come from? I was powering device from OBD test rig that just supplies power.
I will give device reset and reconfigure as you suggest, however I think issue will remain. At least in my instance it seems to be signal related, device report’s excellent signal on GSM page (GPRS Disconnected) but logs show signal is almost non existent or has lots of noise. Also logs shows the device tries to ask to join as IMS which is Volte and most IOT sims do not have as no voice which gets denied as SIM is data only.
Also worth noting mine did start working but lasted like a week before it stopped working again.
Logs from yesterday:
[2026.01.26 15:53:20]-[NETWORK] GPRS open waiting for retry TMO: 26
[2026.01.26 15:53:20]-[NETWORK] ERROR @ m2m_network_api.c(2361):[GPRS.OPEN.0590] Error: 17
[2026.01.26 15:53:25]-[NETWORK] ERROR @ m2m_network_api.c(2361):[GPRS.OPEN.0590] Error: 17
[2026.01.26 15:53:30]-[NETWORK] ERROR @ m2m_network_api.c(2361):[GPRS.OPEN.0590] Error: 17
[2026.01.26 15:53:40]-[NETWORK] ERROR @ m2m_network_api.c(2361):[GPRS.OPEN.0590] Error: 17
[2026.01.26 15:53:47]-[ATCMD] << AT+CREG?
[2026.01.26 15:53:47]-[AT.RSP] Status: 2 (Not Registered, But searching)
[2026.01.26 15:53:47]-[ATCMD] << AT+QCSQ
[2026.01.26 15:53:47]-[ATCMD] >> +QCSQ: “NOSERVICE”
[2026.01.26 15:53:47]-[ATCMD] << AT+CESQ
[2026.01.26 15:53:47]-[AT.RSP] #RSRQ: -13.5 dB | #RSRP: -118 dBm
[2026.01.26 15:53:47]-[ATCMD] << AT+QNWINFO
[2026.01.26 15:53:47]-[ATCMD] >> +QNWINFO: “FDD LTE”,“23420”,“LTE BAND 20”,6175
[2026.01.26 15:53:50]-[MDM.ALT] Trying with primary APN (CID 1)
[2026.01.26 15:53:50]-[ATCMD] >> +CGDCONT: 1,“IP”,“ims”
[2026.01.26 15:53:51]-[ATCMD] >> +CME ERROR: Excute command failure
[2026.01.26 15:53:51]-[ATCMD] >> +CREG: 2,3 (Registration Denied)
[2026.01.26 15:53:51]-[AT.RSP] Registration Denied
[2026.01.26 15:53:51]-[MDM.ALT] Trying without auth mode with primary APN
[2026.01.26 15:53:51]-[AT.RSP] #RSRQ: -10.5 dB | #RSRP: -105 dBm (Improved strength)
[2026.01.26 15:53:52]-[ATCMD] >> +CREG: 2,3 (Registration Denied)
[2026.01.26 15:53:55]-[MDM.ALT] Trying without auth mode with secondary APN
[2026.01.26 15:53:55]-[ATCMD] >> +CREG: 2,3 (Registration Denied)
[2026.01.26 15:53:56]-[MDM.ALT] Failed to activate PDP context with any APN
[2026.01.26 15:53:56]-[NETWORK] ERROR @ m2m_network_api.c(2361):[GPRS.OPEN.0590] Error: 19
[2026.01.26 15:54:17]-[AT.RSP] Status: 2 (Searching)
[2026.01.26 15:54:17]-[AT.RSP] #RSRQ: -10.0 dB | #RSRP: -107 dBm
[2026.01.26 15:54:17]-[ATCMD] >> +CSQ: 15,99 (3-4 Bars indicated)
[2026.01.26 15:54:18]-[NETWORK] ERROR @ m2m_network_api.c(2361):[GPRS.OPEN.0590] Error: 17
[2026.01.26 15:56:17]-[ATCMD] >>[134] +CPAS: 0
[2026.01.26 15:56:17]-[ATCMD] >>[134] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+CIMI
[2026.01.26 15:56:17]-[WD.FUNC] WARNING @ 239:[1] counter:1 Cnt:300 Limit:1800
[2026.01.26 15:56:17]-[WD.FUNC] WARNING @ 239:[1] counter:2 Cnt:298 Limit:1800
[2026.01.26 15:56:17]-[ATCMD] >>[173] 234201911410619
[2026.01.26 15:56:17]-[ATCMD] >>[173] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+CREG?
[2026.01.26 15:56:17]-[ATCMD] >>[139] +CREG: 2,2,“04fe”,“001a2000”,7
[2026.01.26 15:56:17]-[AT.RSP] Status: 2
[2026.01.26 15:56:17]-[AT.RSP] Area Code: 1278
[2026.01.26 15:56:17]-[AT.RSP] Cell ID: 1712128
[2026.01.26 15:56:17]-[AT.RSP] Registration Mode: 7
[2026.01.26 15:56:17]-[AT.RSP] Not Registered, But searching for OP
[2026.01.26 15:56:17]-[MODEM.ACTION] WARNING @ 1254:Modem Status Update forced, skipping checks [rsn: 3]
[2026.01.26 15:56:17]-[ATCMD] >>[139] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+QCSQ
[2026.01.26 15:56:17]-[ATCMD] >>[132] +QCSQ:“NOSERVICE”
[2026.01.26 15:56:17]-[ATCMD] >>[132] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+CESQ
[2026.01.26 15:56:17]-[ATCMD] >>[229] +CESQ: 99,99,255,255,15,54
[2026.01.26 15:56:17]-[AT.RSP] #RSRQ: -12.5 dB
[2026.01.26 15:56:17]-[AT.RSP] #RSRP: -87 dBm
[2026.01.26 15:56:17]-[ATCMD] >>[229] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+QNWINFO
[2026.01.26 15:56:17]-[ATCMD] >>[133] +QNWINFO: “FDD LTE”,“23420”,“LTE BAND 3”,1363
[2026.01.26 15:56:17]-[ATCMD] >>[133] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+CSQ
[2026.01.26 15:56:17]-[ATCMD] >>[131] +CSQ: 29,99
[2026.01.26 15:56:17]-[ATCMD] >>[131] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+CFUN?
[2026.01.26 15:56:17]-[ATCMD] >>[152] +CFUN: 1
[2026.01.26 15:56:17]-[ATCMD] >>[152] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+COPS?
[2026.01.26 15:56:17]-[ATCMD] >>[135] +COPS: 0
[2026.01.26 15:56:17]-[ATCMD] >>[135] OK
[2026.01.26 15:56:17]-[ATCMD] <<AT+CMGL=4
[2026.01.26 15:56:17]-[ATCMD] >>[137] OK
[2026.01.26 15:56:17]-[MOD.TSK] SMS Read Map:0,0,0,0 Index:32
[2026.01.26 15:56:17]-[MODEM.ACTION] SMS Not Found
[2026.01.26 15:56:17]-[MODEM.ACTION] status done
[2026.01.26 15:58:00]-[MDM.ALT] Trying without auth mode with secondary APN
[2026.01.26 15:58:00]-[ATCMD] << AT+QNWINFO [2026.01.26 15:58:00]-[ATCMD] >> +QNWINFO: “FDD LTE”,“23420”,“LTE BAND 3”,1363 (Three UK detected)
[2026.01.26 15:58:00]-[ATCMD] << AT+CGDCONT? [2026.01.26 15:58:01]-[ATCMD] >> +CGDCONT: 0,“IP”,“ims”,“0.0.0.0” [2026.01.26 15:58:06]-[ATCMD] >> +CGDCONT: 1,“IP”,“ims”,“IPV4:0.0.0.0”,0,0
[2026.01.26 15:58:17]-[ATCMD] << AT+CGAUTH? [2026.01.26 15:58:31]-[ATCMD] >> +CGAUTH: 1,1,“”,“” [2026.01.26 15:58:52]-[ATCMD] >> +CREG: 2,3,"
0675",“000da301”,7 (Registration Denied)
[2026.01.26 15:59:23]-[AT.RSP] Registration Denied (Status 3)
