I am using an FMC003 with firmware 04.01.00.Rev.13 in a 2024 Tesla Model 3 Highland.
I need a definitive technical answer regarding continuous GNSS operation and AVL reporting.
My required operating conditions are:
The FMC003 receives a continuous, permanent external power supply within its specified input-voltage range.
Sleep Mode is configured to No Sleep (0).
Standard Ignition I/O is monitored independently of OBD data. In my installation, Ignition changes to 1 immediately when the Tesla wakes.
The FMC003 must continue operating 24 hours a day, including while the vehicle is parked and asleep.
The GNSS receiver must remain active continuously, maintaining satellite reception and obtaining fresh position fi
xes while the vehicle is stationary, subject to satellite visibility.
The device must continue generating and transmitting periodic AVL records throughout this period.
The application requires reliable 10-metre geofence exit detection. Following a vehicle wake-up, waiting until the vehicle has travelled hundreds of metres before obtaining a fresh GNSS fix is unacceptable.
Could you please confirm the following:
With permanent external power and Sleep Mode set to No Sleep, will the FMC003 keep its GNSS receiver continuously active while Ignition is 0?
Will it continue acquiring fresh GNSS fixes while stationary, rather than periodically suspending GNSS operation?
Can periodic AVL records be generated and transmitted continuously, with each record containing a fresh, valid GNSS position fix?
Under what circumstances can an AVL record contain the last known coordinates instead of a fresh fix? Which configuration parameters prevent records without a current position from being saved or transmitted?
Are there any other configuration parameters, firmware limitations, or power-management features that could suspend GNSS operation even when Sleep Mode is set to No Sleep?
Can you confirm that this configuration is supported on firmware 04.01.00.Rev.13, and advise whether a firmware update is required?
Please distinguish between the device’s ability to remain powered and the ability to provide fresh, valid GNSS coordinates in every AVL record.
Please find the clarification regarding FMC003 GNSS operation below.
GNSS operation with No Sleep
With permanent external power and Sleep Mode set to No Sleep (0), the FMC003 will not enter GPS Sleep, Deep Sleep, Online Deep Sleep, or Ultra Deep Sleep because of Ignition changing to 0. Therefore, the GNSS receiver is intended to remain active while the vehicle is stationary.
Fresh GNSS fixes while stationary
The active GNSS receiver will continue processing satellite data and updating its position while stationary, provided that adequate satellite reception is available.
However, remaining powered and having the GNSS receiver active does not guarantee a valid fix at every moment. The device may temporarily lose its fix because of antenna placement, obstruction, underground or covered parking, interference, or insufficient satellite visibility.
Periodic AVL records
Periodic records can be generated and transmitted continuously by configuring the required On Stop Min Period, Min Saved Records, and Send Period values. Setting the Min Period to 0 disables time-based record generation, so a non-zero value must be configured.
Nevertheless, Teltonika cannot guarantee that every periodic record will contain a newly calculated valid GNSS position. Record generation and GNSS-fix availability are separate processes.
Last-known coordinates
If an AVL record is generated when the GNSS receiver does not have a valid fix, the record may contain the last valid latitude, longitude, and altitude. Such a record can normally be identified by the GNSS-related fields, including zero satellites and a GNSS Status value indicating that GNSS is on without a fix.
The GNSS Status values are:
1 – GNSS on with fix
2 – GNSS on without fix
3 – GNSS sleep
The Records saving/sending without TS setting controls whether records are saved without valid time synchronization; it does not guarantee that each record has a current GNSS position fix.
Static Navigation
Static Navigation must also be considered. When enabled, it filters coordinate changes while the configured movement or ignition condition indicates that the vehicle is stationary. This can make the reported position appear frozen even though the GNSS receiver remains active.
For reliable detection of a 10-metre geofence exit, I recommend disabling Static Navigation during testing. Alternatively, configure its source so that the filter is deactivated immediately when the independently monitored Ignition changes to 1.
Firmware compatibility
Firmware 04.01.00.Rev.13 supports No Sleep mode, continuous GNSS operation, Static Navigation configuration, and periodic On Stop record generation. A firmware update is not required specifically to enable this behaviour.
In summary, the requested continuous operation is supported, but no GNSS tracker can guarantee a fresh valid fix in every AVL record. For this application, use No Sleep, disable Static Navigation, configure a suitable non-zero On Stop record interval and Send Period, and use GNSS Status on the server to distinguish current fixes from records containing last-known coordinates.
Hi Imran.S, working through possible solutions to my problem taking into account your previous reply, it is evident I cannot provide permanent power and have Ignition return 0. My trials strongly suggest that Ignition is not a vehicle state but an FMC003 state. The FMC003 while powered returns Ignition as 1.
Is there any way to provide continuous power to the device without impacting Ignition?
