FMC 650 battery
Hi.
We are using the FMC650, and trying to understand the use of the battery. It is possible to set the FMC650 to report GPS/GNSS data every 5 min for 1 hour after the ignition is turned off?
Thanks for your answers :slight_smile:
Good day, after ignition and movement are not detected the device will change its mode to Onstop.
From the data acquisition, you can change the parameters according to your requirements but the device will report every 5 mins after the ignition is off, there is no option for the device to report every 5 mins only for 1 hour after the ignition is off. But in case you need this feature you may contact your sales manager so he can check if firmware development is possible for your project.
Wiki page link: FMC650 Data acquisition settings - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
