FMBXXX - Connect to Azure Device Provisioning Service
Good day. I would like to connect Teltonika Tracker Devices to Azure IoT Device Provisioning Service (DPS). However, when I look at the Teltonika Documentation, I can only find this possible while making use of Teltonika’s WebUI (which seems not to be available for FMB devices). Is it possible to do this while making use of the normal configurator software with the tracker devices?
I would kindly appreciate any assistance given in regards to this issue.
Azure IoT is available using the latest firmware of teltonika device: Getting started with Azure IoT hub - Teltonika Telematics Wiki
You can configure the device using the normal configurator.
Please download the latest firmware here: Getting started with Azure IoT hub - Teltonika Telematics Wiki
Best Regards
Maynard C
