FMB920 GPRS is deactivated
Hi I have a FMB920 which states that the GPRS is deactivated. I know the sim works and I have updated to the latest firmware. I have tried everything I can think of. Do you have any tips.
Please check the following.
  1. Simcard slot if it is having physical damage.
  2. check your device configuration,
  3. check the ICCID if it is detected.
  4. check if the actual operator code is detected.
  5. change the simcard and try to put it on another device in case it works probably there is an issue with your device.
If the device is still covered by the warranty kindly contact your sales manager for the RMA process.
Regards
Maynard C.
1; Looks ok
2; I have but I might of missed something.
3; ICCID was detected on another phone
4; operator code comes as 0 network is three
5; Works fine
So are you using a 2G sim on the device or a 5G sim?
How many devices are affected by this issue?
If this is only 1 device you can check with your sales manager for the RMA process or create a helpdesk ticket to investigate the issue. If you don’t have any contact with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it. Note: as a topic, please choose “Vehicle telematics”. Or you can send an e-mail with a description of your situation to info@teltonika.lt When contacting Us, please provide: IMEI/Logs/Configuration file/Intenational GSM number/Firmware version/ect , please follow these recommendations: Recommendations for filling a query description - Wiki Knowledge Base | Teltonika GPS
I guess you have it I’m using a 5G sim card. Will change for 2G
This topic was automatically closed after 5 days. New replies are no longer allowed.
