I need help with the following, it’s quite urgent.
My FMB204 does not charge, even though the “Battery Charge Mode” is set to “Always”.
The conditions are:
- The device is turned on, using the internal battery only, not connected to the external power.
- The device enters Ultra Sleep Mode after some time (in my case after a minute or so).
- External power turns on.
The device will only start charging if it wakes up (via the accelerometer or ignition).
Configurator: 1.8.10.B.4.00_R.7
Firmware: 04.00.00 Rev:13
Configuration: 12.0.0.0
Please help.
Thanks.
