FMB120 with LVCAN 300 on Linux 2020
Hello all,
i have installed a FMB120 on Toyota Hilux 2020 with LVCAN 300 for fuel monitoring.
in the configurator i used the program number of the Toyota Hilux 2021 (13592) and i don’t receive any data on the tracker. Can anyone help me please ?
Thank you.
Good day!
Where did you take the connection for CAN, and which CAN line do you use? Please let me know. Once you update the information, I can assist you if it is possible.
kind regards.
I made the connections on the cables that are behind the dashboard counter. I used Can1 L and Can1 H the (brown color).
You can see it on the picture.
Thank you.
Your connection is correct, and the program number is as well. Could you please provide one screenshot of the configurator showing the status bar of the CAN adapter? I need to make sure that the CAN adapter firmware is updated.
kind regards.
could you send a screeshot of how it should be? because if go to the client again without a solution it’s very bad for me. Or can we update the firmeware with the fota web ? Can you also give me rigth programm number of the Toyota Hilux 2020 for the can 300?
Thank you.
Good day!
Kindly note, you can find the firmware version for the CAN adapter attached in the screenshot.
Thank you
kind regards.
Amalnath
