Hello.
After apply “OBD Device Debugging - Wiki Knowledge Base | Teltonika GPS” no data OBD OEM of my Dacia Spring (vehicle supported for FMB003), I obtain VIN only.
Any solution?
Many thanks.
Hello.
Any solution?
Many thanks.
Good day, for the EV please add the vehicle manually and select OBD non-compliant.
Please also use the latest firmware for you FMB003: https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.03.29.00.Rev.359_and_configurator.zip
If the solution didn’t work, please contact your sales or create an HD ticket, and include the following.
Note: Make sure that the SIM of the device is connected to the FOTAWEB
If you don’t have any contact with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it.
Best Regards
Maynard C
Hello Maynard.
Yes, I have used https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.03.29.00.Rev.359_and_configurator.zip, and no result.
Yes, tested as Non-OBD compliant and inserted VIN manually, no result (OEM file no created and no protocol Obd2 recognized, only show VIN in OBD section of configurator, data selection in LOW priority mode appears in blank).
