I get the VIN number when I use bluetooth commands, but I do not get it as part of the AVL in the GPRS data.
Do I have to enable any parameter so I receive the VIN number in the AVL?
In order to receive the VIN Number as part of the AVL, first you need to set the VIN parameter to Low priority. Kindly go to Open Configurator > go to OBD II > search for VIN > set priority from None to Low.
After configuring the parameter, you will received the VIN number through AVL ID 256. For more information about FMB003 data sending parameter, you may refer on this link: https://wiki.teltonika-gps.com/view/FMB003_Teltonika_Data_Sending_Parameters_ID#OBD_elements
I hope this helps.
Patrick
