i was wondering is it possible to capture the TPMS data from the dash screen of the Actros mp4 Via FMB 640
Hi @Brando
If the data is available from the CAN you can try to use the MANUAL CAN : FMC640 Manual CAN IO - Teltonika Telematics Wiki
If it is not available you need to use a separate TPMS sensor: FMC640 ContiPressureCheck - Teltonika Telematics Wiki
Best Regards
Maynard C
