Hello, we want to be connected to severals RUT200 with fixed IP from a RUT200 with also a fixed IP so that we can use it everywherre.
For the moment it is not OK. I wonder if there is specific rules to input so that it could be possible.
If I understand correctly, you want to monitor and manage these devices remotely. The best option would be to configure a VPN connection.
We have a wiki page that outlines all the VPN options available for the RUT200: RUT200 VPN Setup. Here, you can find detailed instructions and information about each VPN type.
If I misunderstood your request and you’re looking to configure something else, please provide more details, including the network topology and all device IPs. Thank you!
Hello Marija, thanks for your help, i give you more details.
We succed to connect to a RUT200 (we call it RUT A which is in the house of a client connected to a heat pump) from the fixed IP of our company with a normal internet network. We use SIM CARDS Things Mobile, each SIM card gets a fixed IP.
We want also connect to this RUT200 (RUT A) with another RUT200 (we call it RUT B which has his own fixed IP) so that we can connect to RUT A everywhere we are (we want to use the RUT B internet network).
But for the moment it doesn’t work. That’s why I wonder if there is specifics rules to manage directly in the RUT B. I Hope it’s more clear for you.
Thank you for the clarification. As I mentioned earlier, I believe the best option would be to set up a VPN where RUT A acts as the server and RUT B as the client. This setup will allow you to connect to RUT A using RUT B from anywhere. I hope this clarifies why I recommended using a VPN.
Please let me know if you have any further questions regarding this.
