Faulty 5G modem update in RUT M30
Hi all,
In my RUT M30 I was presented with the update of the internal modem firmware version from my previous RG520NEBDCR03A05M4G to RG520NEBDCR03A06M4G which I did and it was reported as “completed successfully”.
Now I have connection issues on the RUT M30: It slowly blinks the 5G-mobile-LED (3 bars) in red while the WiFi-LED cycles amber-green-blue. I updated the modem while being on device firmware 7.23.0. After that, I updated the device to 7.23.5 but that didn’t change anything. On my second RUT M30 I then skipped the modem update and updated to 7.23.5 and everything works as before, so it is not the device firmware version or any of our 5G infrastructure that has an issue.
The faulty device reports
“All available APNs were tried on the 5gmob1s1a1 interface, unable to make connection to operator, try to enter custom APN or adjust mobile settings to make connection”
Sometimes it shows very briefly the network in “https://192.168.1.1/status/network/mobile” but also other 5G networks it should not connect to as it is configured to only connect to our 5G standalone network.
Very briefly it shows the correct IMSI of the SIM card and a suitable ICCID. It sometimes also shows the correct Cell ID, the correct band 5G N78, the correct ARFCN, the correct Mobile country code and the Mobile network code. At the same time it says: “Data connection state: Disconnected” but “Connection stage: Setup complete”. When it succeeds to show signal quality measurements, it reports “Connection stage: Unknown” while it properly shows good signal strengths.
Due to the modem update policy I cannot downgrade the device’s modem firmware to the A05 version. How do I fix this? Can I do something about it in the CLI shell?
Philipp
Greetings @fhg-iosb,
There are known issues associated with modem firmware version RG520NEBDCR03A05M4G, and a newer release has been introduced to address them.
To continue the investigation, I kindly ask you to perform the following steps:
  • Download a troubleshooting file from the device by navigating to System → Maintenance → Troubleshoot and clicking Download.
  • Download the latest firmware version for the router from the following page:
    RUTM30 Firmware Downloads - Teltonika Networks Wiki
  • Perform a firmware reinstallation using the bootloader menu. A detailed step-by-step guide is available here:
    RUTM30 Device Recovery Options - Teltonika Networks Wiki
  • After reinstalling the firmware, please verify whether the issue has been resolved.
  • If the issue persists, reproduce it and download a new troubleshooting file immediately afterwards.
Please note that both troubleshooting files will be required for further investigation if the issue is not resolved following the bootloader procedure.
Please let me know how it goes.
OK now I could do all of the above.
I had already done a full reset by long-pressing the reset button, but there was no change. With the bootloader-based update I changed also from 7.23.5 to 7.23.6 but nothing changed. The issue is the modem firmware and not the device firmware.
I can’t upload the troubleshooting logs as my user is too new.
The LED blinking is unchanged to before.
EDIT: To be clear, the updated version RG520NEBDCR03A06M4G is causing problems for me while the older RG520NEBDCR03A05M4G worked. At least it gave no immediate errors.
@Vilius Do you want the troubleshooting logs by mail? Is there anything more I should test?
Would you please give me some guidance on how to proceed after that faulty update?
Bump!
Please may someone share their insights about the issue?
Is your current modem FW version is RG520NEBDCR03A06M4G_A0.300.A0.300 ?
I am on RG520NEBDCR03A06M4G but don’t see any sub-versioning. If you tell me how to obtain the sub-version, I will check.
I for the first time also got a message in the message center (bell icon) that says:
“Mobile 5GMM reject cause: N1 mode not allowed”
However, I was not in reach of our 5G SA network in this case.
OK found it:
gsmctl --firmware
yields
Then need more attention from Teltonika support. Probably to send them troubleshoot file when problem occurs. @Vilius @Marija
Thank you. I sent them already troubleshooting files but haven’t heard back.
I also tried to reboot the modem with gsmctl -Q and to set it to debug with gsmctl -D but the issue remains.
Apologies for late response,
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 19693.
I filled out the form. @Vilius
Is there any feedback about the investigation? I basically would just like to downgrade to the working firmware for the moment.
I have sent you additional troubleshooting steps via email, please let me know about the outcome. This will greatly assist in our investigation.
Thank you for your cooperation.
