Hello
Please guide me to factory reset 1110 and 920
Thank you
Have you read the manual?
You’ve also posted in the wrong community. You need to ask your question in the Telematics community but I suggest you read the manual first.
Hello @anico,
I hope you are doing well. You may send an SMS command to factory reset the device on its default configuration through the command mentioned below.
defaultcfg
On the other hand, if you have connected the device through USB Cable you may set the Reset Configuration button through the Configurator.
Patrick S.
