Eye beacon receiver antenna
Hello Everyone!
Our construction company use FMB trackers for our excavators, trucks and vans. This year we started use BLE Eye Beacons and put them into the smaller machines, like diesel generators, electric hammers, trench rammers,vibratory plates and stuffs like that, so the FMB trackers recieve the Beacon signal, and we know the position of the small machines. Occasionally I use EyeApp on my phone to track the Beacons.
Sadly, the smaller machines sometime are “gone” (stolen). I’m looking for a solution with a higher range receiver. Maybe there is a third-party antenna with higher receiver gain what I can use with the smart phone or FMB moduls to reach the weaker signals from Beacons.
Hope, someone has a good advice.
Peter
Currently ; there’s no third-party antennas have been used to increase the beacon’s signal strength
In the Eye app’s beacon configuration settings, you can increase the signal power. Higher transmission power levels result in a stronger signal, so try to adjust the power up to 8 dBm for a range of up to 8meter.
Be noted that increasing the power will effect the battery life of beacon ; please check the graph from link EYE FAQ - Wiki Knowledge Base | Teltonika GPS
Regards
Maryam
Dear Maryam!
My question didn’t aim to attach third-party antenna to BLE Eye Beacon, but to attach third-party antenna to receiver. Trying to increase the receiver sinsitivity.
Regards
Maryam
This topic was automatically closed after 3 days. New replies are no longer allowed.
