Extraction of DATA (FMC003)
Once the Teltonika configurator is set up, what is the best method to extract all device data in real-time?
The most common and scalable method is to configure your device to send data via GPRS to a server platform:
Configure Device Server Settings:
  • In the Teltonika Configurator, navigate to the GPRS section
  • Set the Domain and Port to point to your data collection server
  • Configure data protocol (typically Codec 8 Extended for maximum parameter support)
Using Flespi Platform for Real-Time Data Access
Flespi is used as a telematics middleware platform to receive, parse, and forward data from GPS tracking devices to various systems, enabling real-time integration, device management, and data routing.
Key Configuration Requirements for Real-Time Data:
  1. Disable Sleep Mode - Ensure continuous data transmission
  2. Set Appropriate Min Period - Configure how frequently data is generated
  3. Set Appropriate Send Period - Configure how frequently data is sent to the server
  4. Configure Min Saved Records - Set to 1 for immediate data delivery
  5. Enable GPRS Connection - Ensure proper APN settings and server configuration
