Thank you for your patience, and apologies for the delayed response.
MRP is a Layer 2 ring redundancy protocol defined in IEC 62439-2. It is widely used in PROFINET networks, but it does not require PROFINET. You can use it to build a redundant ring between switches even if PROFINET is not running on the network.
Regarding your setup, we are not aware of any issues with our switches using MRP in a ring consisting of 40 switches, with a 500 ms recovery time.
ERPS (ITU-T G.8032) is designed for faster recovery, typically under 50 ms, and ERPS v2 supports multiple connected rings. However, our switches do not currently support ERPS. For ring topologies, our TSW202 and TSW212 switches support MRP and also RSTP/STP.
If your network does not exceed 50 switches and a 500 ms recovery time meets your requirements, MRP should be a suitable solution for your application.
Hope this helps clarify the differences. If you have any further questions or would like to discuss your network topology in more detail, please don’t hesitate to reach out.
