Event Juggler and Geofences
Is it possible to use the event juggler on an RUTX50 to only trigger once on an event happening. The issue I have is that I want to trigger once when a vehicle with a router leaves a geofence. I only want it to trigger again after it has returned and departs again. As far as I can see the condition is triggered every sample interval.
Greetings, LongtownMRT,
Yes, this can be achieved using the Geofencing feature. Geofencing allows you to define a virtual boundary on the map and configure rules that notify you when the device enters or leaves that area.
You can access this feature by navigating to Services → GPS → GPS Geofencing. There you can create a rule by specifying the coordinates, radius, and the event type. In your case, selecting Enter/Exit will ensure the device reports whenever it crosses the defined boundary.
For more detailed information, you may refer to the following article:
If you have any further questions or need additional guidance, feel free to let me know — I’ll be happy to help.
Warm regards,
