EVC2 OCPP 1.6: CertificateSigned rejected with "value[issuer] : mismatch"
I’m trying to get Security Profile 3 working on an EVC2 (firmware v2.3.1) with our own OCPP server, and I’m stuck on the client certificate.
We use our own self-signed CA. I installed the root with InstallCertificate, and GetInstalledCertificateIds shows it with the right serial number. The charger then sends SignCertificate with a CSR, we sign it, and when we send it back in CertificateSigned the charger replies:
PropertyConstraintViolation, “value[issuer] : mismatch”
As far as I can tell the certificate is fine. The issuer matches the subject of the installed root exactly, and it passes openssl verify against that root. O also matches CpoName. I get the same error on Security Profile 1 and 2.
What is the charger comparing the issuer against? Does the CA need to be set up in a specific way, or does this flow need to run over wss with a server certificate from the same CA?
Also, is there a way to put the client certificate and private key on the charger directly? The app only lets me select files that are already there.
Thanks!
Thank you for the detailed information.
The error PropertyConstraintViolation: value[issuer] : mismatch typically indicates that the issuer of the certificate returned via CertificateSigned does not exactly match the CA certificate installed on the charger.
Could you please verify that:
  • The CSR was signed directly by the CA certificate installed using InstallCertificate.
  • The issuer DN in the signed certificate exactly matches the subject DN of the installed CA certificate.
  • No intermediate CA certificates are involved.
Regarding manual certificate installation, uploading a client certificate and private key directly through the app is currently not supported. The intended workflow is to install the CA certificate, generate a CSR, sign it externally, and return it using CertificateSigned.
Kindest regards,
Džiugas-Teltonika
