On my TeltoCharge EVC1 running firmware 1.16.4, I tried reducing charging current through OCPP 1.6J using TxProfile at stack levels 0 and 5 (the reported maximum). The requests were accepted, but actual current did not decrease.
Applying the same lower limit using ChargePointMaxProfile worked.
Is this a known issue, or does TxProfile require additional configuration?
Thank you for the detailed information and for providing both the request and response payloads.
Based on the information provided, the behavior you observed is expected with the current EVC1 firmware implementation.
Although the charger returns an Accepted response to the SetChargingProfile request containing a TxProfile, the charging current may not be actively limited by TxProfile in all firmware versions and operating scenarios. In contrast, ChargePointMaxProfile is the recommended and fully supported method for dynamically controlling the maximum charging current, which is consistent with your test results.
To rule out configuration-related causes, please ensure that:
The charger is running firmware 1.16.4.
The charging transaction is active when the profile is applied.
The correct transactionId is being used.
No other charging profile with a higher priority is overriding the TxProfile.
Smart Charging functionality is enabled and correctly configured on the OCPP backend.
That said, if the charger successfully applies current limits through ChargePointMaxProfile but does not react to an accepted TxProfile, this generally indicates a limitation of the current firmware implementation rather than an issue with the OCPP request itself.
For EVC1 chargers, we therefore recommend using ChargePointMaxProfile for load management and dynamic current control.
FW 1.16.4 is not updated on SW releases page, neither there are release notes published for it.
Could it be updated please ? It was very easy to work with that page while it was updated in the wiki
Also, based on my experience with previous charger’s OCPP support I want to ask the burden of the profiles switching on FLASH/NAND/EEPROM - how often can server side send each of those profiles without trashing the storage over time … if some profiles get persistently stored on - maybe there is a profile we can use that is not stored and has no influence on storaging aging
