eSIM Profiles lost RUT981 - 7.24.7
We lost our eSIM Profiles on RUT981 Routers after Upgrading Router to 7.24.7.
After the Update no new Profile were accepted and also a downgrade of Router brings them not back.
Does anyone else have this problem, and is there a way to restore the profiles?
Additional Infos:
lpac modem0 get-profiles
ES10.GetProfilesInfo
at_utils__CSIM_response_to_APDU:
failed to parse the data of the APDU
Segmentation fault
The eUICC returns a large GetProfilesInfo response of 5030 hexadecimal characters. The response contains the existing profiles, including profile icon JPEG data. liblpac fails in at_utils__CSIM_response_to_APDU() and subsequently crashes with SIGSEGV.
From System.log:
Fri Nov  6 08:27:22 2026 daemon.info procd: Service event: type=instance.start, service=mobifd, instance=instance1
Fri Nov  6 08:27:23 2026 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Fri Nov  6 08:27:24 2026 kern.info kernel: [80697.398643] do_page_fault(): sending SIGSEGV to mobifd for invalid write access to 00000000
Fri Nov  6 08:27:24 2026 kern.info kernel: [80697.407244] epc = 77e1059c in libc.so[77dec000+aa000]
Fri Nov  6 08:27:24 2026 kern.info kernel: [80697.412456] ra  = 77bd13ed in liblpac.so[77bcb000+42000]
Fri Nov  6 08:27:24 2026 daemon.info procd: Service event: type=instance.stop, service=mobifd, instance=instance1
Fri Nov  6 08:27:24 2026 daemon.info procd: Service event: type=instance.respawn, service=mobifd, instance=instance1
Fri Nov  6 08:27:34 2026 daemon.info procd: Service event: type=instance.start, service=mobifd, instance=instance1
Fri Nov  6 08:27:34 2026 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Fri Nov  6 08:27:36 2026 kern.info kernel: [80709.080385] do_page_fault(): sending SIGSEGV to mobifd for invalid write access to 00000000
Fri Nov  6 08:27:36 2026 kern.info kernel: [80709.089006] epc = 77e0659c in libc.so[77de2000+aa000]
Fri Nov  6 08:27:36 2026 kern.info kernel: [80709.094205] ra  = 77bc73ed in liblpac.so[77bc1000+42000]
Fri Nov  6 08:27:36 2026 daemon.info procd: Service event: type=instance.stop, service=mobifd, instance=instance1
Fri Nov  6 08:27:36 2026 daemon.info procd: Service event: type=instance.respawn, service=mobifd, instance=instance1
Fri Nov  6 08:27:46 2026 daemon.info procd: Service event: type=instance.start, service=mobifd, instance=instance1
Fri Nov  6 08:27:46 2026 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Fri Nov  6 08:27:48 2026 kern.info kernel: [80720.791336] do_page_fault(): sending SIGSEGV to mobifd for invalid write access to 00000000
Fri Nov  6 08:27:48 2026 kern.info kernel: [80720.799864] epc = 77e1f59c in libc.so[77dfb000+aa000]
Fri Nov  6 08:27:48 2026 kern.info kernel: [80720.805110] ra  = 77be03ed in liblpac.so[77bda000+42000]
Fri Nov  6 08:27:48 2026 daemon.info procd: Service event: type=instance.stop, service=mobifd, instance=instance1
Fri Nov  6 08:27:48 2026 daemon.info procd: Service event: type=instance.respawn, service=mobifd, instance=instance1
Thank you for reaching out.
We are investigating the reported behavior.
To identify the exact cause and provide a solution, we would like to continue the conversation privately. We have sent a form to the email address associated with your forum account. When completing the form, please enter the ID of this thread 21849 in the Ticket ID field.
Once you have submitted the form, please let me know by replying to the thread. We will then contact you privately to assist you further.
T.
Form submitted—Thank you for contacting us
Thank you for completing the form! I have reached out to you by email. When you have time, please check your inbox.
T.
