I’m having the same problem described in another topic (TLS problem (WebGUI)). Unfortunately, this topic was automatically closed with no resolution.
When trying to set HTTPS certificate using GUI on TRB255 with firmware TRB2_R_00.07.11.2 an error is logged when saving configuration changes. Syslog record error message ?:0: attempt to index a nil value
Problem occurs when trying to use self-signed server certificate or externally signed and uploaded certificate and key pair.
We have reopened the topic you provided. Regarding the issue, our developers are actively working on resolving it. The fix is expected to be included in a future release updates, but unfortunately, I don’t have a specific date.
I will post any updates here as soon as I have more information.
Thank you for your patience and understanding.
Thank You for quick confirmation.
For anyone having this problem, I was able to circumvent the problem by manually setting certificate and key file paths in /etc/config/uhttpd - options option cert and option key
