Good day,
Would anyone be able to give me some direction on the following error which occours when compiling the RUTX SDK fimrware for a RUTX12 device.
Only amendments to the branding have been made. I am compiling on Ubuntu 22.04 and have followed the instructions on: RUTOS Software Development Kit (SDK) Instruction - Teltonika Networks Wiki
I have done:
./scripts/feeds update -a
make clean
make -j1 V=sc
make[4]: Entering directory '/home/build/projects/teltonika-firmware/PFORTNER_RUTX/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/hs_theme_default-2022-07-27'
make[4]: *** No targets specified and no makefile found. Stop.
make[4]: Leaving directory '/home/build/projects/teltonika-firmware/PFORTNER_RUTX/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/hs_theme_default-2022-07-27'
make[3]: *** [Makefile:55: /home/build/projects/teltonika-firmware/PFORTNER_RUTX/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/hs_theme_default-2022-07-27/.built] Error 2
make[3]: Leaving directory '/home/build/projects/teltonika-firmware/PFORTNER_RUTX/package/feeds/vuci/tlt_hotspot_theme_default'
time: package/feeds/vuci/tlt_hotspot_theme_default/compile#0.08#0.22#0.28
ERROR: package/feeds/vuci/tlt_hotspot_theme_default failed to build.
make[2]: *** [package/Makefile:127: package/feeds/vuci/tlt_hotspot_theme_default/compile] Error 1
make[2]: Leaving directory '/home/build/projects/teltonika-firmware/PFORTNER_RUTX'
make[1]: *** [package/Makefile:121: /home/build/projects/teltonika-firmware/PFORTNER_RUTX/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.package_compile] Error 2
make[1]: Leaving directory '/home/build/projects/teltonika-firmware/PFORTNER_RUTX'
make: *** [/home/build/projects/teltonika-firmware/PFORTNER_RUTX/include/toplevel.mk:249: world] Error 2
