after using commandline in email relay i figured out that you need option “–client-tls-connection” instead of “–client-tls” but how am I able to setup this function in GUI for “email relay”?
after using option “–client-tls-connection” i am able to forward emails to strato
Please ensure your device is operating on the latest firmware version 7.10 (7.06.16 for EOL), as it has improvements and issue fixes.
If updating to the newest firmware does not resolve the issue, then please share your Email Relay configurations from the WebUI here. Thank you!
I am already using port 465, really? and intern I am using port 25. And using same configuration per command line but with option --client-tls-connection and not --client-tls works
Why not just add a option for --client-tls-connection in the gui and problem would be fixed?
