ECAN02 indicator light operation
I’m connecting some FMC650 units together with ECAN02. I’ve confirmed with an oscilloscope that I have both CAN+ and CAN- the correct way round and have a steady state green light on the ECAN02. Should this light flash when data is being received.
Dear @MarkH,
I hope you are doing well. Please find below the Wiki Link that discussed the LED indication status for ECAN02, also more information regarding the ECAN02 can be found on the same link.
ECAN02: ECAN02 - Teltonika Telematics Wiki
I hope this helps.
Patrick S.
Hi Patrick
Living the dream, hope you are too.
I’ve seen the information before but now had a closer look since you shared and noticed the light can be either steady or flashing, both states show normal operating condition. Is there a reason why I should see different states at different times, data transfer rate?
Many thanks for your reply.
Have a great day.
