Duplicate config between RUT241
On a RUT241, I am looking to transfer a configuration that suits me to another RUT241. What is the method?
Thank you
Frederic
Hello @fred_1,
Our apologies for the delayed response.
The simplest method to transfer a configuration to a device would be by generating a backup file.
A configuration backup file contains a device’s entire configuration information, including the admin password. After you create a new backup file, you can use it to restore the configuration of the current device or upload it to other identical devices effectively applying the configuration to them.
To generate a configuration backup file, follow the steps described below.
  1. Configure the device according to your needs.
  2. Go to the System → MaintenanceBackup page and click the ‘Download’ button
You can upload configuration backup files to your device if they were generated on an identical device using the same or an older firmware version. Note that backup files created on devices with newer firmware cannot be uploaded to devices using an older firmware version.
To upload and apply a configuration backup file via the device’s WebUI, follow the steps described below.
  1. Go to the System → MaintenanceBackup page.
  2. Click the ‘Browse’ button and find your backup file on your computer.
  3. Click the ‘Upload Archive’ button.
For more information regarding configurations backups, please refer to our wiki article:
Alternatively if the device is connected to RMS, you can create a template from a configured device and edit it after the selected parameters have been uploaded to he template.
For step-by-step guidance, please refer to the following wiki page:
Please keep in mind that devices you’re trying to configure must be Online, otherwise, the Device configuration option will be grayed out.
If you have any questions or need further assistance, feel free to reach out.
Povilas
