DUAL CAM with FMB641
I need to know that i am having FMB641 device i want to attach Dual Cam/Dash Cam with FMB641 device. Using the attached wiring diagram below. But when i open the configurator and the device is attached so i won’t get the dualCam section.
Which firmware and configurator i need resolve the above issue
Hello usman and thank you for your inquiry.
Unfortunately, the dualcam is not compatible with the FMB641, so there isn’t a firmware version available to enable it on this device. However, if you need to use dualcam with an FMx device, you may consider models such as the FMB125, FMC125, FMB225, FMC225, and FMC650. For more information on how to configure dualcam with these devices, please visit the following link:
DualCam Configuration - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
We’ll be happy to assist you with any further questions you may have!
I hope this helps!
Best regards.
