Downoad Certificate for WebUI
I have a RUT955 (firmware R_00.07.06.3), I enabled HTTPS access for the WebUI and activated forwarding for HTTP access.
How can I download the device certificate in order to add it to my certificate store? Is there a possibility to download the cerfiticate through SSH?
Best regards
You can find the certificates in this folder: /etc/ssl if you’re used to accessing our routers via SSH/CLI. Alternatively, they can also be found at System → Administration → Certificates if using the router’s WebUI is more convenient for you.
