Double NAT connection between two RUT955
I have two routers I want to ping from one device connected to one router, to another device connected to the other router.
Router A has an IP of 192.168.1.1 and has two devices connected to it. one with .100 and .64.
Router B has an IP of 192.168.2.1 and has two devices connected with the same fourth octet being as the first router.
I tried to make A client for B and give it a static IP of 192.168.2.150 in the WAN interface. I can ping devices of router B from the CLI of router A. This is working as it should be.
The problem is from B side. I can only ping router A from B ping 192.168.2.150 and i get a response back, but i cannot ping any devices of router A.
I did make a static route from B side but i cannot see the devices still (I added a picture for it)
This is how the interface is made from A to B
Do I need to allow some firewall settings to allow connections from LAN to WAN or vice-versa on ony of the routers?
Regards
Hello Voiar
Welcome to the Teltonika Community :smiley:
Is it possible for you to draw the topology, in a simple way with IP’s so i would be able to replicat ethe same here in the Test Bench
this would ensure that I can be able to test in your exact setup and give you updates
Dear Rashid,
I added image for the network topology.
What matters for me is to keep the ip of both devices the same. I don’t want to change any of IPs for both devices. The connection (sending files/ping) should happen between ip 192.168.2.100 and 192.168.1.100 back and forth.
Hello
Thanks for the Topology
Could you try the following option in Network>Routes>Static Route of the Router B
After this restart the router and try
Let us know if the issue persist
Hi Rashid,
Thanks a lot, it did solve the problem, شكراً.
Have a good day
