Do not close topics after a timespan has elapsed
This expands upon:
…due to:
The reason that I request this is that I may have discovered a solution, only for someone to provide a much better one, later on. This frequently occurs on other forums; especially, Discourse instances. It has occurred here, too, just before a topic was to be closed, after I had marked someone else’s comment as a solution, on one of my topics.
Hello @RokeJulianLockhart,
When the Solution button is pressed on a comment, the topic is automatically scheduled to close after 3 days. This is done to prevent further comments on topics that have already been resolved and to keep discussions focused. If users encounter additional questions or issues, they can create a new topic to continue the discussion without reopening an already-resolved one.
However, if you discover a better or alternative solution after the topic has been marked as solved, you can create a new topic explaining your solution and include a link to the original topic. This way, anyone visiting the original topic will also be able to find your alternative solution through the link.
I hope this clarifies the reasoning behind the automatic topic closure.
@Marija, all that that does is disincentivise me from using the solution plugin. I would much rather not be forced to go to the work of creating new threads every time I want to add information to an existing topic: it breaks the information up into multiple places, which assists nobody.
Hello @RokeJulianLockhart ,
Thank you for clarifying your point. We understand your concern, and agree that creating separate topics for additional information or alternative solutions can split the discussion and make it harder for other users to find all relevant information in one place.
The purpose of automatically closing solved topics is to keep discussions organised and prevent unnecessary follow-up comments. However, we understand that this approach also limits the possibility of improving or updating an existing discussion.
Your suggestion is valid, and we will share this feedback with the team for consideration.
Thank you for taking the time to explain your perspective.
