DMVPN without IPSEC
Hi all,
I need to setup a multipoint GRE tunnel with NHRP to our core router for a customer. I’m trying to achieve this with the DMVPN service on a Teltonika RUTX09 but i need to specify IPSEC settings. As we do not use IPSEC for this specific tunnel interface on our core router i need to set this up without it on the Teltonika.
Is it possible to achieve this in the WebGUI or only in the CLI?
Apologies for a delayed response.
The easiest option would be to configure DMVPN normally, and then navigate to Network → Routing → Dynamic Routes → NHRP (tab) → Edit your instance → Disable IPSec support:
Hope this helps!
Thanks, it works now!
