Different ip and one network for lan port
Hello
Can I assign different IP address to one LAN port?
  • LAN1: 192.168.2.1
    192.168.103.5
    192.168.103.6
  • LAN2: 192.168.127.25
  • LAN3: 10.01.01.01
Yes, it is possible using untagged (or tagged) VLANs. You can find a configuration example here. I would also recommend taking a look at this article here that demonstrates how to manage traffic between VLANs.
But on Lan1 I wan three IP adres!
To have multiple IP addresses on your interface, you can use IP aliases. For this, create a new interface in Network → LAN. Give it a static IP address first, and then, in physical settings tab, put @lan as a custom interface.
