Device name UNKNOWN
I have a RUT360 device that after firmware update the device name is UNKNOWN, both at config/system file and at mnf_info program.
I cannot use a backup from other device to configure it, it says that the backup is not valid.
Is this a known problem? How can it be solved?
Thank you
To address this matter effectively, I’ve sent you a form to fill out. When completing it, please use 12582 as the ticket ID. Once submitted, we will contact you privately and request the necessary information to resolve this issue.
