Device continue to send CanBus params despite Priority==0
hi,
we have FMB240 (IMEI: 352016700561350, FW ver: 03.27.13_03) connected to a canbus adapter.
i sent the command below to stop sending most of the cunbus fields, several times in recent hours and i got feedback that all params accepted.
but still the device continue to send most of the canbus fields. the vehicle made several trips (ignition on/off) in the meantime.
why this happens? is there a bug? what am i doing wrong?
setparam 46030:0;46040:0;46050:0;46060:0;46070:0;45250:0;45260:0;45290:0;45300:0;45310:0;45320:0;45330:0;45890:0;45900:0;45910:0;40210:0;45650:0;45660:0;45670:0;45680:0;45690:0;45700:0;45710:0;45720:0;45730:0;45740:0;45750:0;45760:0;45770:0;45780:0;45790:0;45800:0;45810:0;45820:0;45830:0;45840:0;45850:0;45860:0;45870:0;45880:0
here is a screenshot of the latest message from device
Double-check the syntax and parameters in your “setparam” command. Any syntax errors or incorrect parameter values could result in the command not being executed as expected. Mybkexperience Ensure that you are using the correct parameter IDs for the canbus fields you want to stop.
all these been checked. all values are correct, syntax is correct, i get response from device with all new values as 0.
but still device continue to send fields.
Hi
Please try to send cpureset command if it does not work.
Please contact your sales manager. If you don’t have any contact with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it. Note: as a topic, please choose “Vehicle telematics”. Or you can send an e-mail with the description of your situation to info@teltonika.lt When contacting Us, please provide: IMEI/Logs/Configuration file/Intenational GSM number/Firmware version/ect, please follow these recommendations: Recommendations for filling a query description - Wiki Knowledge Base | Teltonika GPS
