Detecting shift change on 2024 Tesla Model 3 - No stalks
Is there any way to know when the Tesla has shifted from Park into any drive gear. I have an FMC003 connected to the OBD port.
The configurator does not specifically allow for this but can I detect power changes reliably when the drive engages?
Thanks.
Good Day,
The FMC003 does not provide gear-shift information.
The FMC150 can be used to retrieve the current gear data; however, availability depends on whether the parameter is supported for the specific vehicle model and year.
You can check the available parameters for supported vehicles using the following link:
FMX150 Supported Vehicles – Teltonika Telematics Wiki
Thanks, and best regards,
Imran S.
