Deny traffic betweeen WiFi and Mobile
I need to prevent WiFi acces to the mobile network. Mobile & WiFi are used to communicate with a device on lan. Don’t want the user connected to WiFi to use the modem for other purposes.
Here’s a simplified and easy-to-understand tutorial on how to restrict internet access for a Wi-Fi client while allowing communication with other devices in the LAN network(s):
  1. Navigate to Network → Wireless → SSIDs and click “Edit” on your desired Wi-Fi interface.
  1. n the new pop-up window, find the “Network” section, click the dropdown menu, select “Auto(wifi0),” and click “Save & Apply.”
  1. You’ll be prompted to a new pop-up window for the new LAN interface. Here, add a new IPv4 address for this interface. Choose a different network from your main LAN network. For instance, if your LAN network is 192.168.1.0/24, enter 192.168.2.1. Enable the DHCP server by clicking “Setup DHCP Server,” and then click “Save & Apply.”
  1. Now, create a traffic rule to block access to WAN from the newly created LAN network (192.168.2.0/24). Go to Network → Firewall → Traffic Rules, and add a new rule at the bottom. Name it, select Source zone “lan:lan wifi,” Destination zone “wan,” and click “Add.”
  1. In the new window, enable the traffic rule, choose Protocol “All,” set Source IP address to “192.168.2.0/24,” Output zone to “wan,” Action to “Drop,” and click “Save & Apply”. Settings should look like this:
After completing these steps, your Wi-Fi should no longer have internet access.
Marijus
